Greasy Member
Timing belt change
Ok guys, I have a couple quick questions for y'all:
1: What is a usuall shop labor cost for replacing the timeing belt/ tensioner and water pump? 2: How much of a pain in the @ss is the above mentioned process, and about how long does it take. I am an import machanic and have worked on countless Porsches, Lotus, Ferraris, Lambos... etc, just never had the pleasure of doing "heavy" work on a Bimmer. Tools won't be an issue I have two full boxes and a roll around... Thanks for the info, Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
I cant directly answer your questions but...
The E30 timing belt change is outlined here http://www.pelicanparts.com/bmw/techarticles/101-Projects-20-E30-Timing-Belt/101-Projects-20-E30-Timing-Belt.htm and in Wayne's newest book http://www.101projects.com/
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Author of "101 Projects"
I think replacement of the timing belt is actually pretty easy, if you also decide to replace the radiator hoses and water pump at the same time. Everything is very accessible.
Not sure about the shop rates... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Greasy Member
Oh hell, that looks pretty straight forward... I was expecting a "stand on right foot while waving left hand in air, now gently bight lip, and close one eye "either one" now remove timeing belt with specialty tool #78947573...."
Thanks for the info, looks like I know what I will be doing this weekend! Laters all, Nick
many944s,
I would expect a typical shop to charge you no less than $400 for the timing belt change. |
Our water pump super kits are designed to have everything you need for the job:
http://www.pelicanparts.com/BMW/catalog/shopcart/BE30/POR_BE30_ENGcam_pg3.htm#item14 -Wayne
