Send a message via AIM to iamianoliver
Angry 93 - 318i - poor running
hi i have a 1993 318i sedan with 140,000. just recently when i hit the gas hard it sounds like the gas is leaning out and looses power, if i ease in to it it runs fine up until about 4000 rpm then it some times pops. this only happens after warm up, before its exactly how it should be. it made me think ok the O2 sensor is bad, no codes but i changed it anyway. no change. so i then changed the plugs. no change. then i just changed the fuel filter, and added an injector cleaner. took it for a 30 min drive. no change.
to better explain the leaning out it gets real back firey. poping and sutch and about half the power. am i missing any common sensors that could be bad. the car is real reliable and i dont think it could be a head gasket or rings but who knows, i just borrowed a conpreshion tester im gonna do tomorrow. about where should i be on PSI.
any one got any ideas. thanks
1993, 318i
Old 11-21-2006, 06:38 PM
Could this be the MAF, ICV, or the TPS. out of these 3 which ones become active once the car is warm.
1993, 318i
Old 11-22-2006, 12:26 AM
Jeron's Avatar
The TPS and MAF you can test with a multimeter. I doubt it is the ICV. I think it is a vac leak. Take off the intake boot and look for cracks, then check all the vac lines.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-25-2006, 10:01 AM
I agree it sounds like vac leak~~>most common is the vent valve
Do you hear any sucking sounds while car running???
The vent valve is behind the intake area by firewall run ur hand on the bottom and see if it hissesss
Old 11-28-2006, 06:36 PM
gypsyangel's Avatar
Clean looking car, hope you get it fixed, be sure and post back what the problem was if you get it fixed.
gypsy
Old 12-02-2006, 05:10 PM
