performance chip
I have a 325es year: 1986 5 speed manual. I purchased a performance chip from "Turner" but the car did not start. It only started when I put back the stock chip on the "DME"
I purchased another performance chip from "Bavarian Autosport"
same problem, the car did not start, It only started when I put back the stock chip on the "DME"
The "DME' that my car has was re manufactured by "Programa". at www.programainc.com 0 261 200 027
What is causing this problem? How can I correct it?
Old 09-20-2006, 04:54 PM
GIBSON's Avatar
Wow, clearly you've got a problem with the chip and the ignition module. Let me get some good information for you from a good friend of mine who runs REVO chip tuning. I'll get back to you with an answer.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 09-20-2006, 05:23 PM
thank you for your reply, I will be waiting for a positive respond
Old 09-20-2006, 06:08 PM
GIBSON's Avatar
I'm going to post the reply I got from the magager at REVO chips, maybe it will be helpful.
"Is this person saying they have a replacement ECU fitted to their car from this company? If so, maybe there is a mismatch, that although fits and works fine, may have a conflict with the performance EPROM's from the separate tuners due to a slight spec change in ECU module!! Not sure!! It could be that the ECU fitted was just the internal part of the ECU and he fitted into the old case. If the ECU PCB had a different part# and worked, but but the person ordered the Chip relative to the ECU# on the case, then there's a possibility also!
Secondly, it could be just coincidence that both chips have checksum errors or bad files!
Sorry I couldn't be more helpful but feel free to give me a call if you need anything else."
If you'd like to contact the company directly, they may be able to help you in a more direct way. Just let me know and I'll get the contact info to you.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 09-28-2006, 04:44 PM
I just bought a stock DME from from an old 1986 e30, I installed it on my car, no problems the car starts, then I changed the stock chip for the performance chip, the car did not start. I have two DME, my car will start with either one of them, But if I put the performance chip in any one of them my car won't start, Mr. Bruce see if you could help me with that or anyone reading this E-mail massage, What should I do next????
Old 10-03-2006, 06:27 PM
thank you for your replied
Old 01-25-2007, 05:02 PM
