I have a 97 328is and i am having the same problem with the ac/heat. Ive read many of the forums and seemed to find the culprit as a bad final stage unit. So i ordered that and since it was only 20 bucks i grabbed a blower motor resistor pack as well. Well, i changed out the final stage unit and that hasnt seemed to do the trick...so i figured i would go ahead and install the resistor pack as well...maybe that was the problem after all. Well now my problem is, I dont know where the hell this resistor pack is to change it out. Ive read that it should be above the gas pedal near the center console and that i could possibly be facing up toward the steering wheel. Well either i dont see it or something is covering it or its in a different place in my model car. If anyone could possibly help me with this dilemma i would be much appreciative. thanks.
I thought those we two different names for the same part.
We have discussed it a few times here and there are two different resistor pack part numbers. Maybe you ordered both styles. Also, the resistor fixes one type of problem but there is another problem that occurs inside the climate control that can be repaired too. Search this forum and let me know what you find.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
messed up this reply...please look below for the proper reply
well from what i have read one part is called the blower motor resistor final stage unit...and one is just the blower motor resistor. Here is the picture of the final stage unit that i changed out (the first picture)...this is a picture of the old part, i have the new and improved part installed...i just cant find where to install the second part, the resistor...the second picture.
Blower motor resistor final stage unit. Blower motor resistor.
Blower resistor issues in 323iS; did BMW change resistors for one year? Since you replaced your resistor then maybe you have a climate control computer or a motor problem. I think we have discussed these too but here is something on the computer. http://www.geocities.com/e36rulz/HVAC.html
damn....i thought i had read everything i could on the subject....i appreciate your help...my last guess is that i have a capacitor problem in my control unit...since im not an experienced solderer i think i just might let someone else take care of that. Thanks a lot i guess i can put my car back together now...haha!
You might find someone on ebay that will repair the unit. Or get the instructions and go to an electronics repair or a repair individual that IS good a soldering.
