-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Glovebox won'''''''''''''''''t open (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/329723-glovebox-wont-open.html)
Twerner 02-10-2007 05:06 PM
I have a 1988 bmw 325IX and I can't get the glovebox open.. It isn't locked. The handle lifts up but, the door doesn't open!! Anyone know what to do?
BMWCowboy 02-15-2007 05:46 PM
Take it loose from the back & rock it loose
Twerner 02-15-2007 06:02 PM
I have taken the three nuts off that hold the rear hinge in place But, I still can't get it open.. I have tried to shake and twist the whole glovebox and still nothing. I ws able to get my arm up behind the box and reach inside and nothing is binding.. Even if I had to force something and have to order a new part, I don't know what to do!
Terry
LiquidBMW76 02-16-2007 12:50 AM
I'm going by the shop tonight and I'll look at the one we have out back and get an idea about how to get it open.
LiquidBMW76 02-16-2007 09:35 PM
Try prying down the glovebox right near the hinge a little bit. You should be able to see the 2 philips head screws that hold the latches hook. Just unscrew them and it should just fall right out.
Twerner 02-17-2007 07:34 AM
I now have the two philips out that are at the center behind the door. I tried to pull down on the door but, the door doesn't drop down far enough to unlatch.
Terry
BMWCowboy 02-18-2007 01:00 PM
If its NOT locked it should just pull down~~>really hard..have done many that way & have never had a problem
Twerner 02-18-2007 01:12 PM
Do I pull down on the handle or the door itself after the two screws are removed?
LiquidBMW76 02-18-2007 05:10 PM
On the door
