pjv911's Avatar
Send a message via AIM to pjv911
Calling all BMW wizards
I have a 1995 325ic that has a strange problem. Since buying the car 1 year ago the car has had a problem I cant seem to trace.
Basically whats happening is my alternator has a loud pulsing whine regardless of engine rpm or battery charge state. Also doest matter if the electrical system is loaded or unloaded.
Along with the whine is fluctuating light bulb brightness in tune with the whine. The speed of the fluctuation is very rapid. Its apox 200 times per minute. Also its not uniform. It changes speed constantly regardless or engine rpm. Also it never gets faster in relation to engine rpm. It happens whether the engine is hot or cold.
About 6 months ago the alternator took a crap and was replaced with a rebuilt unit. The alternator swap had no affect on this issue.
As for electrical system alterations the only thing done was the install of a stereo amp which was done by the previous owner. It is however wired correctly and shuts off with the head unit. The symptoms happen with the stereo off as well.
Hopefully this is a common issue and somebody will step up with something for me to check. From what I found on a google search it seems these cars have a lighting module and this may be the culprit. However I don't know what or where that is. Nor do I prefer changing undiagnosed parts.
Any help would be greatly appreciated at this point.
Thanks,
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-17-2007, 09:12 PM
Sounds like a short or loose wire coming off the alternator.
1993 318i manual
Old 02-18-2007, 01:38 AM
Sounds like a voltage regulator but if you changed the alternator, you changed the voltage regulator too. I've seen batteries do strange things. Try temp installing a known good battery. Also, check and see if the voltage is changing in time with the whine. If the voltage is changing and the battery is good, then something else is momentarily loading up the electrical system. Not sure what it would be though. I hate electrical issues like that. Very hard to pinpoint. Good Luck
1994 325IC / 1998 328IC
Old 02-19-2007, 11:21 PM
Your Alt pulley is bad~~>very common & you need to replace that & the tensioner
Old 02-20-2007, 04:56 PM
pjv911's Avatar
Is there a way to cornfirm the pulley is bad. What should I look for ? Is it slipping on the shaft ? Same for the tensioner. I apprieciate your input. Thank you.
Kurt Williams
Old 02-20-2007, 06:11 PM
What haPpens is dirt gets in from the back side~~>U can take the belt off & spin it by hand
Old 02-21-2007, 06:03 PM
pjv911's Avatar
Old 02-21-2007, 07:21 PM
u cant read??~~>take off the belt & start up car & see if noise goes away
Old 02-22-2007, 07:39 AM
Jeron's Avatar
Kurt Williams
BMWCowboy isn't saying the alt itself is bad he's saying the test bearing of the tensioner pulley on the alt belt and to replace the alt tensioner itself as well.
You should be able to test the pulley bearing by spinning it by hand. Pull the AC belt and spin that one to see if they differ. There is also a deflector pulley on the alt belt.
Check prices but you will probably want to order these though Pelican the dealer and autopart stores were expensive.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-22-2007, 11:39 AM
