Help - Accident damage
I hit a ladder Friday night at ~60mph - full on. Now I'm feeling some vibrations in the steering wheel, as well as general shakiness. Car seems to pull a bit to the right, and when braking will sometimes just grab and pull one way or the other.
In addition, the check-engine light came on. I did a code check and there are 3 codes all relating to the cat heat sensor. Looking underneath (just on the ground), I can see wires hanging down about the middle of the car.
So before the car goes into the garage for a damage estimate I'd like to have some idea of what could have happened by colliding with a ladder on I-680. I know at least there will be the wiring harness for the cat sensor - maybe the sensor itself if it got ripped out. Other things that come to mind:
Bent wheels
Wheel alignment
Bent/broken steering or suspension components
What steering or suspension stuff would be most vulnerable to this type of accident? What else should I be looking for? Is it possible for the brake rotors to have taken a hit (indirect) and been bent? How about the drive train? Anything else I should be worried about?
I'm worried that there could be lots of subtle damage that will be hard to have diagnosed and I could be left with a car that never feels right again.
...Bruce
Old 03-19-2007, 11:13 AM
Forgot to mention - car is a 1996 328ic.
Anyway, just got back from the shop where we had it up in the air. At first glance, there is at least 1 bent wheel, 2 tires with torn sidewalls, 2 cat sensors, heat shields, and the cross-members under the engine are pretty badly bent. Probably more to come.
Joy oh joy...
Old 03-19-2007, 05:26 PM
Jeron's Avatar
No way you damaged the brake rotors or brakes unless they took a direct hit, which is unlikely. Everything else is fair game. Sorry to hear about it. Call you insurance company.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-20-2007, 08:01 AM
