-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Help trying to fix lifter noise .... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/343447-help-trying-fix-lifter-noise.html)
brothersinc1 04-26-2007 06:20 PM
96 328i 100,000 5/30 oil
Hello, I am trying to fix lifter noise. Please advise to the best method without tearing the motor apart.
I am about to change the oil. Should I run cleaner through the motor first. Seafoam?
What weight oil should I change to (thicker or thinner). Synthetic help?
Thanks for your advise.
Rob[B]
Jeron 04-26-2007 08:15 PM
People will suggest thicker oil.
Unless it is exorbitant I'd just live with it.
IF you have reason to believe you have sludge or build up run some B-12 or Marvel Mystery Oil in the oil right before your next change.
Jeron 04-26-2007 08:17 PM
I usually don't like thicker oil but a 96 might benefit from a 10w-40. I doubt it reduces the noise though.
