supertack's Avatar
BMW Roundel Climate Control Fan
Does anyone know where I can locate the climate control blower fan. It's makin noises at lower speeds & I wanna take a look.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 02-20-2003, 10:19 AM
Senior Advisor
Javier at Pelican Parts's Avatar
In the dash, sometimes accesible through the glovebox or from engine comp against fire wall pass side.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 02-20-2003, 11:31 AM
My '98 328i climate control blower fan is makin noises at lower speeds also unless i'm at the dealership having them look in to it.
Let me know what you found out if ya will.
Thanks,
Rex
Old 02-23-2003, 06:18 PM
supertack's Avatar
I was able to locate the source of the noise, but can't get to it. It sounds like it is coming from the grate directly below the windsheild wipers. To get to it, I believe I'd have to remove the wipers, but even that seemed to have more than meets the eye. I figured I'd just pop off the cap, remove the lug nut & they'd come off. Unfortunately they didn't budge. But the sound is definatley coming from that area. Any thoughts on what It may be?
97 328is
Old 02-24-2003, 03:31 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I believe that the fan is accessed throguh the passenfger compartment.
Old 02-24-2003, 10:09 AM
supertack's Avatar
From under the dash or throught the engine compartment?
When I tried goin through the glovebox (like Javier mentioned), It was an exercise in futility. Sure there are visible screws, but when there removed, the box still doesn't move. Now there is a box attached to the firewall on the passenger side which is covered in a foam like padding, but that doesn't sound like where the noise is coming from. It is definitely coming from the grate under the wiper assembly.
97 328is
Old 02-25-2003, 04:38 AM
Can't wait till supertrack posts his finds as my car does the same things. At first I thought that it's the blower motor that needs to be replaced but it appears that it is almost a universal problem. I thought that my car '95 318is is somewhat older but I see that people with '98 models have the same trouble.
Old 02-26-2003, 02:24 PM
If you guys are talking about a ticking sound that you can hear when the fan is on low, almost like a card in bicycle spokes, I have the same problem intermittently. Can't wait to read what you find on this one!
Old 02-27-2003, 09:56 AM
I have heard that all you need to do is spray some lube into the fan bearings and that should take careof the noise.
Old 02-27-2003, 10:04 AM
Bijan's Avatar
Send a message via Yahoo to Bijan
How do you get to the fan bearing?
Old 02-27-2003, 11:00 AM
Basically jsust spray some non-conductive lubricant into the fan
Old 02-27-2003, 02:15 PM
supertack's Avatar
Jared, are you talking about the blower fan in the dash, or the radiator fan behind the grill?
Also, what type of spray lubricant would you suggest? Would a WD40 work? If I indeed do need to spray it into the blower fan in the dash, how should I get to it?
97 328is
Old 03-03-2003, 06:07 AM
supertack's Avatar
Jared, any word on this?
97 328is
Old 03-06-2003, 06:18 AM
OK, what fan is squeaking? Thats the fan you need to hit with the WD-40.
Old 03-06-2003, 07:59 AM
supertack's Avatar
The fan thats squeeking is the blower on the climate control. Javier said to go throught the glove box, which I had no luck with. It sounds like its coming from the grate below the windsheild wipers, but I can't get to that easily either. How would you lube the climate control fan?
97 328is
Old 03-06-2003, 11:38 AM
supertack's Avatar
Any word, Jared?
97 328is
Old 03-10-2003, 04:05 AM
where the hell is the access to the climate fan?
Old 11-07-2003, 06:36 PM
I am having sort of the same issue...except my fan has stopped altogether.
Old 11-09-2003, 11:49 PM
supertack's Avatar
Since DJ1009 was kind enough to bring this back to the top after 10 months, it's worth revisiting. I still have that forsaken 'clicking' noise, & would love to make it stop. So again, where do we spray the WD40, to lube the fan bearings?
97 328is
Old 11-10-2003, 07:05 AM
supertack's Avatar
What the hell, 4 years never hurt anyone. I never did fix the problem, any clue as to were the climate control fan is located.
97 328is
Old 04-28-2007, 06:59 PM
