1995 m3 5 speed clutch removal
i have a 1995 m3 and the clutch was slipping bad so i am in the proces of removing it and the transmission is ready to drop out but i dont know how to remove the starter. i can get the transmission to slide back about 3 inches and it stops. any help would be good.
1 fun m3 |
bell housing has a dow going to the starter keep prying
gONe |
If the tranny slides back then the starter is disconnected. Like grafhky52 said there are alignment dowels.
But I think you exaggerated on the 3", if its back 3" then you should be off the dowels and only the tranny input shaft should be touching. Make sure it's as level as possible and keep prying gently.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
