E36 a/c evaporator temperature sensor
Got the part from Pelican and I'm asking for help as where to install. This a/c temp sensor is in a different location from the ambient air temp sensor on the driver's side brake cooling duct. One post indicated under the dash on the passenger side. Will pursue but any help/pix out there would be very much appreciated.
1998 Blk 328is |
Look up the part on realoem.com for a diagram of its location.
Thx for getting back to me. Went to site which is great but there's not location indicator. Just diagram of part and price.
According to Bentley the Evap Temp Sensor is on the left side of the heater box. It appears to be toward the bottom of the box behind a duct. The Heat Core Temp sensor is on the shifter side of the box.
Thank you. Will keep you posted.
Blower is fixed. Desperately, I changed out the porcupine resister and guess what? Blower works and has been working. The evaporator temp sensor wasn't the problem. For what it's worth, apparently, there's a new and improved porcupine. Thanks for the suggestions, Jaron. I do appreciate your timely trouble shooting and it's a credit to Wayne that he's hired you.
| All times are GMT -8. The time now is 07:28 PM. |
