mostwired's Avatar
Question A/C freaking out
'96 318i - the A/C control unit stays blank, does not react to any buttons. Sometimes comes up by itself and works fine. Started to happen today - never before - just in time for the hot Florida summer... (sweaty smilie goes here - but it's not available)
Even when the unit is inoperative, the cold air blows out of the vents at speed.
After the car is turned off, the compressor makes bubbling sounds for a while, and if you look at the spindle inside the belt drive spindle, it rotates! (even though the belt and the spindle are stationary).
I checked fuses - all ok. Recently I measured the coolant pressure with a gauge - by opening the valve. Could it be something to do with that?
- Bad control unit? (why does compressor make all these weird sounds then?)
- Bad compressor? (but why does the control unit stay off?)
Any ideas, please?
Old 05-28-2007, 05:57 PM
Jeron's Avatar
Search for capacitor and you will get lots of hits about replacing a capacitor on climate control unit. This may be one of your problems.
Climate control whacked...
I don't know anything about the compressor problems.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-29-2007, 06:25 AM
