Red face oil drain
I've gotten to the place in an 84325e resto where I'm ready to change the oil and have it inspected. However, the oil drain plug turns continuously in either direction. It will not loosen or tighten, but it cannot be pried out. Any ideas?
Old 07-03-2007, 02:00 PM
Jeron's Avatar
Does it leak? If not you can top side extract the oil to change it.
But eventually you'll want to pull the pan and fix the drain plug.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 07-03-2007, 02:08 PM
For some reason, E30's are famous for these oil drain / pan problems. Unfortunately, the only way is to indeed remove the oil pan and then either re-thread or replace it.
Old 07-03-2007, 02:14 PM
