91 E30 318ic
Greetings,
I have a 91 318IC with 138,000; Want to change the water pump because I know they usually go actually before this mileage;
Anyway besides changing the pump, can anyone tell me what else is reccommended to change at the same time?
Thank you!
Bryan
Old 07-20-2007, 05:29 AM
Jeron's Avatar
Hoses and belts will be easy to replace during this job. Thermostat is a common replacement and so is the radiator especially on E36's. Coolant.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 07-20-2007, 05:45 AM
Thanks for the quick reply. Since its a timing chaing and not a belt, was figuring there was a few things to replace.
Someone mentioned the timing chain tensioner which is not supposed to be a big deal.
Thanks!
Old 07-20-2007, 05:59 AM
Jeron's Avatar
I thought you were asking about things that relate to the water pump replacement, as a labor saving technique.
Timing chain tensioner is very easy to replace and on some models it is not expensive. If it is expensive though, I would not just replace it for no reason.
Old 07-20-2007, 06:38 AM
