ok so i was driving my 96 328is to work one morning happened to look down and noticed the car was hot. so i pulled over shut the car off, waited 30 mins to cool it to normal temp, trying to make it to work. 2 mins later it was hot again. Had it towed, so thinking about it, in the winter the car never fully warmed up so i suspected a thermostat. I ordered a genuine bmw unit, drained the radiator, replaced the thermostat, and filled the radiator with the bleeder screw open, and started the car...i get luke warm heat and it seems if i have the cap on and bleeder screw tight, it overheats. so i tried to burp it a few times and if i leave the caps off, it will overflow coolant through where the cap should be, but once i put the cap on and tighten the screw the temperature starts to climb. at that point i can open the caps again and it almost instantly cools down and is ok. i then top off the fluid and recap it and the same thing continues to happen. Any clues or suguestions?
You may have a failed water pump. Has it been changed to a metel one or do you have the original plastic one?
it is original but i think it is working due to the fact that with no cap it will push coolant out the top of the overflow bottle
try filling it with the screw out and let ift sit over night and re check in the morning
gONe |
How many miles are on your car? The water pumps on the E36 are only good for about 85,000 miles, and I'd guess if you have a '96 you've gone long past that.
Your problems are unusual. It sounds like a blockage or restriction.
Was there sludge in the coolant? I'd pull everything off, clean it and check or plastic debris or sludge.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
my thought is the water pump seeing as the lower hose is cool and upper is hot. its got 116k on it. im going to try a water pump tomorrow...
where is the bleeder located on the M3 thermostat housing..???
Dumb question I know so sorry |
so i decided to take a look at the water pump after findoing out about the plastic impeller, sure enough it was broken into about 3 pieces...installed a new BMW one and it runs great
This is the reason I asked in my previous post. The E36 with a six has a lot of the quirks like the POS plastic water pump. Your failure description was text book for a water pump failure.
thanks for all the help
