Adding Freon To 04 325i
Where is the nipple to plug into for adding freon? I heard it was around the firewall of the car but where?? Help as summer is approaching......
-Blanksta21
Old 03-18-2008, 07:53 PM
Greasy Member
many944s's Avatar
I'm not sure exactly where it is located on your particular model year, but if you follow the lines from the compressor to the rest of the system, you should find them in a fairly accessible area. (The service port may even be located AT the compressor)
There will be two lines at the compressor. The thinner of the two is the HIGH side. DO NOT ATTACH TO THIS PORT!! The line that is larger in diameter is your low (or suction) side. This is the port you want to add refrigerant through.
With most R134a systems the service ports are easily accessible from the top of the engine bay.... finding them is the tricky part!
Good luck,
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 03-25-2008, 07:17 PM
Follow the suction line (the big one) as it goes from the compressor to the firewall, it has to be there somewhere, it can't be anywhere else. I don't know if your model has a accumulator tank, if so it would be in the suction line, at the firewall, and usually will have the low side charging and pressure switch mounted on it.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 03-28-2008, 11:51 PM
