Talking Video of my engine being weird. Suggestions needed!
http://www.youtube.com/watch?v=-qpGzmRWtzk
BMW 325is 1995
Video of my engine knocking with a funny smell. Gonna have it looked at Monday but wanted a second opinion so I know how much of a financial situation I'll be in. I appreciate it!
best,
george
Old 01-04-2008, 12:51 PM
Turns out to be spark plug issue where the problem just got worse over time. Due to the fact the spark plug was tightened a bit too much thereby being stripped. Since this happened it caused oil to squirt out & since the mechanic fixed it, its still gonna be problematic until I take that gasket head out & replaced.Otherwise I would need to get a drill bid tool that will seal the worn out part where the spark plug went. Gots to call the shop back with a decision on this.
Old 01-10-2008, 05:41 PM
Jeron's Avatar
I guess I missed your original post. You can certainly hear the loose plug.
I had a loose plug, not stripped though. I could hear the deep exhaust put-put-put that is in your video. But yours also has a whoosh for the intake stroke since the leak was obviously much bigger than mine.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-10-2008, 07:14 PM
Anyone know where I can get long enough drill bid to thread the part where the spark plug goes into?
Old 01-12-2008, 09:28 AM
Jeron's Avatar
I don't see how you can re-thread the spark plug hole in the head with the head in the car. Call a head shop (automotive machine shop) and ask then what your options are.
Old 01-13-2008, 07:12 PM
helicoil or tap...they know what they're doin
Old 01-14-2008, 08:49 PM
By re-tapping the spark plug holes while the head is on the engine, you are at a serious risk of dropping metal shavings into the head.
Old 01-15-2008, 05:23 AM
Jeron's Avatar
You didnt say they, you asked where you could get a drill bit that would reach the threads.
Either way good luck.
Old 01-15-2008, 07:14 AM
otherwise who know what they'll charge for me for the drill bit alone.it was suggested in hopes of speeding up the process. they found one though so i'm all good.
Old 01-16-2008, 09:42 AM
Exclamation
It's not a drill bit you (or your mechanic) needs, it's a tap. But as others have stated, it's definitely NOT a job you do with the head still on the block. Neither is installing a Heli-coil or other thread repair insert, which is what needs to be done by the way you describe the loose plug. Simply retapping the hole will not repair it. What it almost certainly WILL do is introduce a bunch of metal chips and dirt from the existing threads to the inside of your engine, and that will shortly introduce you to a very large and ugly repair bill. I would be extremely leery of any mechanic that wanted to attempt a repair with the head still in place on the engine.
Old 01-17-2008, 08:03 PM
Got my ride back two weeks ago & runs real good now. Final cost.............
$ 495.84
Old 01-26-2008, 06:53 PM
Did you buy a time machine, too? You posted 9 days ago that you were looking for a drill bit or tap to help with the repair. Now you say you got the car back 14 days ago, fixed? Something doesn't add up
Did they take the head off to do the repair? (I hope)
Old 01-27-2008, 12:16 AM
Yes
Old 01-31-2008, 09:03 PM
