Overheating Problem?
OK new rebuild on a 1997 328is. New water pump, new thermostat, flushed radiator (good flow), new hoses, no leaks.
The coolant temperature sensor was bad so I bypassed it to turn on the auxillary fan. Let it idle till operating temp, then she revs higher R's and over-heats. What the He77 is happening? Seems like the thermostat isn't opening.
Help Me Please
tbs04
Old 09-03-2007, 02:26 PM
Checked the Thermostat...
it's OK. Then started the engine and expected to see coolant gush out of the thermostat port. Trickle at best. What's up with this POS?
Old 09-03-2007, 03:54 PM
do you have the thermostat in backwards or upside down?
gONe
Old 09-03-2007, 05:36 PM
All is OK now
Thanks shes running! no over heating.
Old 09-04-2007, 06:00 PM
Jeron's Avatar
What was it? Let me guess, air in the sytem.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-04-2007, 06:59 PM
Yes. I had blead the system twice. Guess the third time was the charm.
Old 09-04-2007, 08:16 PM
Jeron's Avatar
Don't feel too bad. I had the same problem recently and I answer overheating questions weekly.
The problem is you cant bleed it if you skip even one of the steps.
1) hot
2) heater on
3) bleed screw open
4) rev the engine to 3k-ish for sustained periods
5) kill engine
6) refill coolant
7) repeat
Old 09-04-2007, 08:51 PM
