-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   ecu does not give signal for ignition coil... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/366003-ecu-does-not-give-signal-ignition-coil.html)
teik_88 09-08-2007 08:50 AM
why the ecu does not give signal for ignition coil(4th cylinder)....e36 320 japan spec....:(
TOTALLYBMW 09-15-2007 06:06 AM
Can be anything from a broken wire to and from the ECU, to a blown transistor or chip in the ECU. Or something as simple as a loose earth wire ...
S ECU Repair 09-25-2007 02:05 PM
usually is the final stage of the ignition coil that goes bad inside the ECU.
