BMW Roundel ecu does not give signal for ignition coil...
why the ecu does not give signal for ignition coil(4th cylinder)....e36 320 japan spec....
Old 09-08-2007, 08:50 AM
Can be anything from a broken wire to and from the ECU, to a blown transistor or chip in the ECU. Or something as simple as a loose earth wire ...
Old 09-15-2007, 06:06 AM
S ECU Repair's Avatar
usually is the final stage of the ignition coil that goes bad inside the ECU.
Old 09-25-2007, 02:05 PM
