-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   strange window problem on E36 convertable (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/367374-strange-window-problem-e36-convertable.html)
whosyadadie01 09-16-2007 02:11 PM
i have a 96 328i convertable and the stangest things happen with the windows ... to start off when i try and close the window it will go up like 1/4 of the way or 1/2 the way and then just twitch and start goin down again and it dows that with both front windows (but not always) ?? and the second problem only happens with the front passenger window .... your just be driving and itll just start buggin out, itll go down slightly then go back up and back down slightly and it will just keep doin that ... that one is really buggin the **** out of me so if anyone has any idea then that would be great, thanks
Yurick 09-16-2007 05:50 PM
daddie,
Your convertible top has a number or limit switches on it. One of them is used to lower the windows automatically when you lower the rag top. Sounds like your problem is in that area.
whosyadadie01 09-17-2007 09:08 AM
Originally Posted by Yurick (Post 3482724)
daddie,
could it have something to do with the door locking cuz it only goes down that 1/4 inch like when you open the door ?
David Bevan 09-17-2007 09:58 AM
Strange window behaviour
I had a similar problem about 6 months ago which sorted itself, then the window dropped down completely and wouldn't go anywhere. i had to take out the window mechanism and fabricate a new coosh bearing drive the original is made of plastic with 3 pegs that break off. i made a new one out of steel using 3 socket head cap screws and a welder. i doubt it will break now!! i have a small machine shop with a lathe and MIG+TIG welding capability. if you don't have this facility you might be stuck! i can provide photos and dimensions if required.SmileWavy
Yurick 09-17-2007 11:00 AM
It could very well have something to do with the door locking system. You did not initially mention that the windows were only giong down a short way. It still sounds like some issues with limit switches, only these are related to the door lock mechanism instead of the rag top.
bsaffin 09-17-2007 01:41 PM
Those switches are right in the door latches. You should be able to test them by pressing the switch when the door is open (window should raise). When you release the switch the window should lower again. Sorry, don't have a picture. I've never replaced those, but they shouldn't be too difficult.
...Bruce
whosyadadie01 09-17-2007 10:30 PM
hows that work if nothing happens when i press the switch ?
WillNZ 09-20-2007 01:06 PM
door switches
My convertible did the same on the passenger side, turned out to be the door latch switch was a bit worn, allowing the switch to make and break contact while driving. I just replaced the latch switch and problem went away.
However, when you have the door open and press this switch, the window should rise, and then fall again when you release it, so if yours is not doing anything, maybe the wiring behind it is loose/corroded? Do both doors not function when you press the individual switches?
whosyadadie01 09-20-2007 10:36 PM
what do you mean by individual switches? the ones one the doors do work. and yea im going to have to take the door panel off and take a look
