Send a message via AIM to sektornj
Question 95 318i sluggish & chk engine light coming on
I'm kinda new to the BMW world and im hoping someone can give me some pointers. I have a 95 318i and she was running like a top.
She started getting sluggish and the check engine light is coming on if you step on the gas (like going up hills, passing, etc..). Starting was a problem too. Fuel economy seem to have gone downhill as well. I replaced plugs, wires, and coil and the starting issue seems to be fixed, but still having hesitation problems and the chk engine light still comes on. I run 93 in the car & synthetic oil if that helps.
I have a new fuel filter but the weather has not been in my favor.
Could it be an O2 sensor?
Any help or pointers would be appreciated.
Old 12-10-2007, 01:58 PM
The Man
Send a message via AIM to whosyadadie01
i would say it is ur o2 sensors but b4 you go drop 300 on new ones, id go get the codes scanned
BMW e36 96 328I convertable
Old 12-10-2007, 09:16 PM
I cant say if its throwing a code or not- the light only stays on momentarily then goes back out. It does seem to be a bit more sluggish when the light comes on, but even when its off, it still not up to par.
Old 12-11-2007, 04:18 AM
Jeron's Avatar
Are you sure the light that is flashing on briefly is the check engine light?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-11-2007, 06:18 AM
Yes. It doesnt flash, it comes on solid and if I let off the gas, it goes out. It will stay off until i step on the gas again to either down-shift or to a higher rpm.
Old 12-11-2007, 08:39 AM
Jeron's Avatar
Originally Posted by sektornj View Post
Yes. It doesn't flash, it comes on solid and if I let off the gas, it goes out. It will stay off until i step on the gas again to either down-shift or to a higher rpm.
I did a little bit or searching and found references to O2 sensors, MAF and ICV. Nothing definitive.
Old 12-11-2007, 10:25 AM
