Fastonez3
The A/C and Alternator belts are making noise when the car is started in cold weather. After a few minutes the noise goes away. I plan to replace both belts myself. Are there any tips that anyone can offer that may help me get this done right the first time?
Thanks. |
The tensioner pulley has a cover over the center that must be removed. Then you need a Allen socket and a long wrench to pull the tensioner back. Spin the pulleys to see if the bearings are good. They should not make noise and should not spin free like a bicycle wheel, they should spin and stop quickly. The tensioners should require a lot of pressure to pull back.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Fastonez3
Thank you for the tips.
The Man
mine are cracking and with the cold weather here i dont want it to break and get stranded in a snow storm
---------------------------------------------------------------------------------------------------- BMW e36 96 328I convertable |
