Question No air coming out of defrost vents
I have Bmw 318I 1992 with a problem I can hear the air running but im getting no air out of defrost vents. I'm also not getting any heat either. Just got car on Ebay and just finding out problems can anyone help me. I have major issues with this car it needs all kind of work but I need this fixed to drive. Winter is here and it is getting cold.
Thanks,
Glenn
Old 12-13-2007, 12:32 PM
Jeron's Avatar
The defrost problem is probably the flapper motor.
The other is covered here and in lots of other threads:
heater question?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-13-2007, 01:12 PM
Where is the flaper motor located is it easy to get to or should i let a bmw service center fix it.
Old 12-14-2007, 12:22 AM
Jeron's Avatar
It is probably not easy to get to but the dealer will be expensive.
I would find it, check if it s getting power, make sure it isn't jammed then replace it. The face and foot vents open and close correctly?
Figure out why you are getting no heat at the same time in case they are related somehow.
Old 12-14-2007, 07:50 AM
The face and foot vents open and close correctly yes but just the defrost doesn't work. What about the no heat issue I am new here this is my first bmw and lost looking at it. Use to old chevy's
Old 12-15-2007, 09:09 PM
