Chris
Rear shock mounts.....do better exist
I have a 95 318is and I am tired of replacing the rear shock mounts every year because of there noise. This is by far the worst designed part on the car.
Does anything recommend any aftermarket or better ones that don't always go bad?
Chris
Old 12-19-2007, 02:01 PM
Try the ones for M3; they should be sturdier.
Old 12-19-2007, 07:43 PM
Jeron's Avatar
Every year is too often there must be something else wrong.
Yes M3 are the stiffest. E46 M3 are the stiffest OEM. You can get Urethane too but even stock ones should last years, not go out every year..
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-19-2007, 11:02 PM
Schneller's Avatar
E46 M3 rear shock are the sturdiest and are what we use exclusively on e46, e36, Z3 & e30s. Urethane is intended for race cars. On the street urethane mounts are too squeaky, too stiff, and will eventually blow out your rear shock towers.
Good Luck!
Schneller
Old 12-20-2007, 10:38 AM
Jeron's Avatar
I have had Urethane RSM's in my M3 for about 2 1/2 years, no noise, no problems. I cant comment on relative ride harshness because I have other modified suspension parts.
For the average person I would recommend the E36 M3 RSM's.
Old 12-20-2007, 11:37 AM
Schneller's Avatar
Jeron Wrote:
"I have had Urethane RSM's in my M3 for about 2 1/2 years, no noise, no problems. "
That's because you live in Texas where it's relatively warm all year and the urethane remains pliable. Here in the Northeast urethane gets hard & shrinks in cold weather (below 30 deg f). In that state urethane isn't pliable, doesn't absorb any road shock & the bushings then squeak & rattle around. All that stiffness then imparts more load on the rear shock towers. Combine that w/ winter potholes & the rear shock towers start to crack.
Just lettin' ya know what we've seen over the 15 years we've been fixing BMWs...
Schneller
Mike Morris
Schneller BMW Performance
26 Middle Rd Unit 1-2
Newbury, MA 01951
978.465.2002 www.machschnell.com
Old 12-20-2007, 12:53 PM
Jeron's Avatar
Seems reasonable.
Old 12-20-2007, 04:36 PM
