spmagee's Avatar
Unhappy Runaway aux cooling fan
Help! My car wouldn't start yesterday after a very cold night (for coastal SC) and when I opened the hood I found that the aux cooling fan was running for no reason, and now the battery is deader than dead.
Is the running fan a reason or a symptom?
Has this happened to anyone else out there?
Thanks,
Sean
'97 E36 328i 5-speed
Old 01-16-2008, 07:20 PM
Jeron's Avatar
I would suspect the fan relay, because I don't think the fan is supposed to run at all with the car off.
I would disconnect the battery, charge it and reconnect. Hopefully the fan will start running again. If so tap on the relay with a screwdriver to see if it ticks off. If it doesn't pull the relay and the fan should stop. Then test the low power trip of the relay to see if the relay is indeed being tripped or if the relay is just stuck.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-16-2008, 08:25 PM
