Oil in Water
I have small globs of oil in my radiator expansion tank. How did this happen and what should I do now? It's a '96 BMW 328iC, 191K miles, runs great. This is the only real problem and I would really like to keep it for many more years.
Old 01-06-2008, 03:26 PM
Jeron's Avatar
Hopefully it is coolant sludge rather than oil. If it is oil it is the head gasket.
You can:
change the coolant and see if that clears it is sludge and clears up
do a leak down test to see if pressure is getting into the coolant
pressurize the radiator to see if pressure/coolant is forced into the oil or cylinders
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-06-2008, 04:47 PM
oil in water 2
Thanks, so how do I tell the difference? What I have is dark brown and oily.
Old 01-10-2008, 03:16 PM
Jeron's Avatar
There are some pictures here:
http://www.pelicanparts.com/bmw/techarticles/E36-Coolant_Flush/E36-Coolant-Flush.htm
Old 01-11-2008, 08:27 AM
oil in water
Do you think I should use a "radiator flush" type additive to clean the system before draining and adding new coolant?
Old 01-12-2008, 07:40 AM
Jeron's Avatar
A radiator flush would not hurt.
When I have used it I:
1) drained and filled with Super Flush and distiled
2) drained and filled with distilled
3) drained and filled with coolant and distilled
But thats 3 jobs, albeit easy ones.
If you are pretty sure it's sludge I would do the 3 jobs. If you think it might be oil in the coolant I'd just drain and fill with tap water until you can determine if you need a head gasket.
Old 01-12-2008, 09:03 AM
