Secondary Air Injection
I'm familiar with the purpose of the system but recently during warmup the whistling has been getting louder until it shuts down. I know there is a filter that sits at the very top of the unit which is enclosed, can the top be removed and the filter be changed or does this come as one unit only?
cook28
Old 01-21-2008, 10:41 AM
Jeron's Avatar
This is an E36?
I have never taken mine apart, I did not think there was a filter.
I would check the in and outlet hoses for restriction. Are you sure the noise isn't a bearing?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-21-2008, 03:38 PM
E36 328i, sure enough, I removed the upper hose that appears to just be a vent because it connects to nowhere and looked inside with a light an noticed this small circular filter. I think the the other hose coming off this part runs to the EGR. I guess I'm more curious if the whistling sound on cold starts is a normal thing.
Old 01-21-2008, 07:30 PM
Jeron's Avatar
The upper inlet hose doesnt go anywhere. The outlet should go to a valve then to the exhaust manifold.
It should sound like a blow-drier on cold starts for about 1 minute, then go off.
Old 01-21-2008, 08:20 PM
I think were ok then. Thanks!
Old 01-22-2008, 09:49 AM
