Rlg4675
check engine light
My check engine light has come on and I did the turn the key on but dont start, pump the gas pedal 5x in 5 seconds thing. It shows a 1 2 2 1 which is a bad o2 sensor. I then tried the hold the gas pedal down for more than 10 seconds thing to turn off the light but, it has not turned off the light. How can I turn off the light?
Old 01-14-2008, 04:00 PM
You will need the scanner or the reset tool.
Old 01-14-2008, 06:13 PM
Rlg4675
Which one do you recomend and where is a good place to buy one?
Old 01-14-2008, 07:11 PM
Peake Research makes one, so does Assenmacher to name a couple, but I am sure that there are others. Pelican carries both, but you can certainly do a little googling to look for additional brands and prices.
Old 01-15-2008, 05:19 AM
The Man
Send a message via AIM to whosyadadie01
peake is what i have and i like it
BMW e36 96 328I convertable
Old 01-16-2008, 10:37 PM
Did you replace the O2 sensor? If not the light won't go off.
92 325I 168K
Old 01-17-2008, 12:00 PM
Rlg4675
No I haven't replaced it yet , I was going to buy a reset/ scan tool at the same time that I bought the 02 sensor .
Old 01-17-2008, 04:26 PM
There won't be a need to reset it after you replace the O2 sensor. granted the O2 sensor is whats causing the fault.
92 325I 168K
Old 01-18-2008, 07:05 AM
Rlg4675
The light will go off when I replace the o2 sensor?
Old 01-18-2008, 07:52 PM
Yes
92 325I 168K
Old 01-19-2008, 06:45 AM
