wiring harness connectors?
Anyone know where I can buy wiring harness connectors for the horn, air temperature gauge and coolant level sensor. the body shop that fixed my car cut all these off when they disassembled the front end and jury rigged them when they put the car back together.
Bill |
Dealer is probably the best place because I suspect part numbers will be hard to come by. Pelican surely sells the parts. You might call them.
You can search http://www.realoem.com Junk yard might be the easiest. I've seen part numbers for the connector to the coolant level sender.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
I need the harness side connectors
That's the problem. The harness side connectors don't appear anywhere because they're part of the harness.
Give me a call...we sell harness parts all the time.
619-444-2290 |
