-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Skip in idle from cold start..... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/393603-skip-idle-cold-start.html)
ellisjay2 02-18-2008 04:01 PM
I've noticed a skip in the ignition when starting from sitting over night, after I run the car for about 5 minutes or so idle gets normal, but I believe its some kind of ignition problem, if a cylinder was mis firing wouldn't that cause backire?? I think one of my wires is or the connection is bad, or maybe its a plug fouled, I'll check it out when I get the chance, only other guess would be a fuel issue to one of the cylinders....??? Any thoughts??
Jeron 02-18-2008 05:48 PM
Have you looked at the plugs?
No check engine light?
ellisjay2 02-25-2008 02:02 PM
Major firing issue...
Skip has gotten worse, I believe my coil or wires are bad, stumbles when driving from low speeds 20-40mph, vibration when idling and rough...
