Skip in idle from cold start.....
I've noticed a skip in the ignition when starting from sitting over night, after I run the car for about 5 minutes or so idle gets normal, but I believe its some kind of ignition problem, if a cylinder was mis firing wouldn't that cause backire?? I think one of my wires is or the connection is bad, or maybe its a plug fouled, I'll check it out when I get the chance, only other guess would be a fuel issue to one of the cylinders....??? Any thoughts??
95 318is, stock, burgundy exterior, 2 one baige interior, automatic, 180kmiles
Old 02-18-2008, 05:01 PM
Jeron's Avatar
Have you looked at the plugs?
No check engine light?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-18-2008, 06:48 PM
Question Major firing issue...
Skip has gotten worse, I believe my coil or wires are bad, stumbles when driving from low speeds 20-40mph, vibration when idling and rough...
Old 02-25-2008, 03:02 PM
