90 E30 325i fuel level reads about 1/3 tank all the time
I've replaced the fuel tank level sender on the under the rear seat on the passenger side of the car. I'm still getting a reading of about 1/3 tank most of the time.
Any suggestions?
Brian in Austin
Old 03-07-2008, 07:21 AM
Jeron's Avatar
There are two sending units.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-07-2008, 07:33 AM
Are the two fuel tank sending units interchangeable
Im guessing the other sender is on the other side of the car??
Anyone know if the two sending units are the same?? Can I use the one I took out of the passenger side of the tank in the Driver's side location??
Brian
Old 03-07-2008, 07:48 AM
Jeron's Avatar
Look up the part numbers on Pelican or Realoem to see if they are the same.
Also check for damaged wiring.
Old 03-07-2008, 07:54 AM
