nicknikolovski's Avatar
Engine Whine - BMW M42 1.8L
Hi, I have a 93 318is M42 motor.
I just recently replaced my entire timing chain assembly.
I changed the cam, crank & idler sprockets, the tensioner, tensioner & main guide, the upper & lower guides, the timing chain and all relevant gaskets.
I also changed my thermostat, water pump and all 3 belts.
When I started my engine, I got that rattling sound then the oil pressure stablized and everything was perfect. After bleeding the cooling system, I went for a drive and noticed a whinning sound coming from the engine during acceleration between 1500-3000rpm. Also during deceleration using engine braking between 3000 & down to idle.
Is it normal for the M42 to whine loudly? It sounds like there is a supercharger bolted on. Could it just be the new timing components need to settle in or wear in?
Any help or advice would be appreciated greatly.
Thanks, Nick
Old 03-24-2008, 02:55 AM
Jeron's Avatar
I usually associate a whine with a bad bearing, usually in one of the deflector or one of the tensioner pulleys.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-24-2008, 08:47 AM
