e-36 runs for a while and just dies
i am having a big problem with my 95 325I. I did the head last year and change the fuel pump september(07). This year I went away for two weeks, when i come back the car won't start. I change the crank and the cam pos. sensor nothing I check to see if I had fuel pressure I did, I swap the computer and the relay nada, I brought it to a mechanic he said that he reset the computer and change the relay to charge me a ton of money, the only thing is now the car start but and run to a period of 10 minutes then dies, if i start it again it will run for another 10 minutes then dies and won't start for the third times til the car cool off. I forgot to mention I change the ICV and the coolant temperature sensor. Can somebody please help me with my problem????
Old 04-04-2008, 02:49 PM
does no one feel me?
Old 04-04-2008, 06:33 PM
Jeron's Avatar
Sounds like after it exceeds the cold start open loop it dies. I"ll have to think on it.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-04-2008, 10:20 PM
tanx
Old 04-06-2008, 09:17 AM
Had the same problem a few months back. It was the air ass meter - right above the air filter. Got a used one for replacemnt and it worked. Might want to check the air intake manifold downstream of the meter as well for cracks.
Old 04-10-2008, 09:06 PM
I'LL try that tanx
Old 04-11-2008, 08:05 PM
air mass meter is it the same as air flow meter
Old 04-11-2008, 08:07 PM
Jeron you never get back to me.
Old 04-12-2008, 02:01 PM
Jeron's Avatar
I still haven't come up with anything, even after a weekend in Vegas and lots of scotch, imagine that.
Does it always die after the same amount of time? Do you drive it for 10 min and it dies while driving or can you just start it and let it idle for 10 min and it dies?
Old 04-13-2008, 06:53 PM
Mass air meter is just behind the air filter housing, before the intake elbow.
It has a round screw out plug. Hard to miss, it's right on top on my 93.
On mine if you unplug it, or forget to plug it back in, ( I just told on myself) it will go into limp home mode, and the check engine light will go on.
It won't quit running, just run a little rough.
Is your check engine light coming on, and have you down loaded the fault codes?
Also, I might mention, I had a similar problem with my 88.
It was a bad ignition switch.
When it starts to shut down try turning the key back and forth just a little.
Or, when it wont start at all, don't let it return all the way back from the start position and see if it tries to fire.
By the way, the best time to try and diagnose the problem is when it won't run at all.
Much easier to find.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 04-14-2008, 05:32 PM
IT is both , it like when the car warm up it just dies driving or not drivin, I also did a test, the fuel pump stop running every time the car is going to die. I check the current in the fuel pump fuse, before the car dies, the current shut off in the fuse and when the car dies, the current flows back that is very weird. when i try to do the code I got 1000
Old 04-15-2008, 05:48 PM
yes my check engine light comes on when th car dies...
Old 04-15-2008, 08:01 PM
