Squeaky steering wheel in my e36.
I've a '93 318is with 184K miles on it, and the steering wheel is starting to bug me. It has developed a slight squeak in the steering wheel.
It's a very thin, soft squeak, almost like bedsprings, and doesn't do it consistently. I can turn normally, with no added effort, just a small squeak.
Any ideas, folks? I can't hear it outside the car, so I'm inclined to think it's the wheel- steering column nut.
By the way, I'm new here. Hi!
Old 04-09-2008, 05:20 AM
Jeron's Avatar
It's the Air Bag contact ring. Common, sort of a PITA from what I've heard. I never have bothered fixing mine, its sooo far down the list of things I need to do.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-09-2008, 08:47 AM
Would lubrication help, say a few good drips of mineral oil?
Old 04-09-2008, 09:31 AM
Jeron's Avatar
Lubricating it sounds familiar but I think it was hard to get to and the lube only lasted a very short time. Sorry, I don't recall exactly. There are DIY on the replacement on the web. There was one published in Roundel years ago.
Old 04-09-2008, 11:55 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
The slip ring in the steering wheel might be takin a dump or need to be greased.
Air Bag light is on & No horn
Not a hard fix to lube or replace. If you hear "springs" I would tend to think the inner parts of the ring are deteriorating.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-16-2008, 09:44 PM
supertack's Avatar
I've had the problem for a long time too. The funny part is, it seems to go away in the warmer months, & rear it's ugly head when it's really cold out.
Disconnecting the air bag, & taking off the steering wheel is somethin' I never put high on the priority list as well.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-17-2008, 05:44 AM
