1987 325es
i have a 1987 325es needs engine swapped what models and years can i use
Old 05-18-2008, 10:45 AM
Jeron's Avatar
You may not find people with that info here.
Are you looking to swap simply engine only, engine & DME or a substantially different engine?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-18-2008, 10:48 AM
what would be easiest
Old 05-18-2008, 12:22 PM
first things first. Do you have to meet an annual/biannual smog test? If so, chances are good that you will really only be able to use one that is the same as what you have.
for example, suppose you had an S10 pickup that came with a GM 2.8 V6 and need to replace it but were subject to Calif smog. You would find that trying to upgrade to a 3.1 could be nearly impossible because the 3.1 would not pass the visual inspection in most places.
Old 05-18-2008, 02:18 PM
