94 325 tapping noise
I have a 94 325 I with 100k miles and I just started to hear a tapping sounds that changes with the RPM. the noise is not loud when the engine is cold. its coming from the VANOS unit area and it just start getting louder. I'm thinking its the chain Tensioner. Would the upper chain that goes from the intake cam to the exhaust cam make that noise? And if so can you change the upper tensioner with out removing any of the chains. Plus should I change the lower chain Tensioner 1st?
Old 05-19-2008, 05:51 PM
Jeron's Avatar
The lower tensioner is very easy to replace.
I would get a mechanics stethoscope and try to isolate the noise.
You should read DrVanos.com
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-20-2008, 07:05 AM
