noisey e36
hi peeps
when i fist start my bmw 316 up its sounds ok but when running the engine as a rattle like tappets noise and runs realy slugish a bit kangarooy until the engine warms up then it runs fine and no noise
what could be causing this
Old 06-26-2008, 05:12 AM
Jeron's Avatar
Does the sluggishness correspond with the air pump running? It sounds like a blow drier and only runs on cold starts for about 1 minute.
Some lifter noise is common on start up and should become quiet when the engine warms and has been run at medium RPM for a minute or two.
Another possibility is the chain tensioner.
Determining where exactly the noise is coming from is best done with a mechanics stethoscope.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 06-26-2008, 08:30 AM
what do mean buy the air pump ?
the car seems to get to temp invery qwick eg with 0.3 miles
Old 06-26-2008, 12:52 PM
Jeron's Avatar
The air pump is an emmissions device. The 316 is a euro model right? You probably dont have an air pump.
Old 06-26-2008, 01:58 PM
