Instrument cluster
Recently disconnected battery on 1997 318i to work on ignition lock cylinder and check fuel pump. When reconnected the speedometer, fuel gauge and MPG indicators are not working. The RPM, temp gauge and lights all work. ????
Checked all four instrument cluster fuses-all good. Could I have loosened a connection when accessing lock mechanism? Any next step suggestion? |
If you pulled on the wires to the ignition you could have pulled one of the plugs to the cluster loose. Also check the instrument cluster ground, If I remember right, it is on the steering column near the lock cylinder.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed 85 325e bought new, totaled after 20 years & 465K miles, trouble free service. 01 Ford Ranger 4dr stpsd 4wd. I drive,here 88 325i convert. only 98k miles,gone, sold 93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone |
Ground splice
I could not locate the instrument ground. I read something where there could be a problem with the ground splice for the fuel and speed sensor?? This makes sense since it is just the fuel gauge and speedo/odo and MPG gauges that quite working.
Author of "101 Projects"
I would start with the obvious - inspect the plugs and harnesses on the back to see if any got inadvertently damaged. Also, the cluster's operation is somewhat related to the ignition switch - there may be a power lead from the switch that is loose or broken...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
E36 SI Board battery?
Does the SI board on a '97 318i have batteries similar to the E30's. I've removed and separated the cluster and cannot locate the batteries. I was planning on changing out athe batteries in hope that they were the source of my gauges problems.
