e36 325i no engine start
95 325i
when turn on the starting key i can hear the normal buzz or whirr engine sound and starter motor. but the engine it self wont continue running. My question, is that what else should i check to work it out...
Thanks for the help
Old 08-26-2008, 06:45 PM
Did you recently get water on the firewall by washing the engine or driving in deep water?
Water in the DME, which is mounted on the firewall toward the passenger side, will knock out your spark. Search this forum for tips on repairing/replacing a DME.
Can you hear the fuel pump spin up for a second when you turn the key to the On position? If not, start by checking the fuse for the fuel pump.
Old 08-26-2008, 09:37 PM
Jeron's Avatar
Are you saying it sounds like it is started but when you release to key from START to the ON position it dies?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-27-2008, 07:16 AM
