hello -I have 1998 328 i that my daughter drives------the plastic heater pipes broke off were heater hose connect to heater pipes ,at the fire wall --------this really got me mad when I saw what there made of, -plastic-,anyway do I have to pull dash out to replace the 3 heater pipes ? anyone have this problem ? and why would they break? maybe car overheated ? thanks AL
Don't like the sound of that because both my daughters drive '97 328s - even have the same wheels. Heater control valve runs $160 on line. Ouch.
The heater control valve replacement is an under-hood job. No need to attack the dash. Small hands and small tools will come in handy. That car would have been due for heater hose replacement recently. PITA job. Any chance that the tubes were abused during that job, leading to failure? |
heater pipes
no, its not the heater valve that broke --------its were the heater valve hose connects to the 3 plastic tubes[nipples] at the fire wall------thats what broke, ------my question is ,do I have to pull the dash out to fix that? ---thanks
http://www.realoem.com/bmw/showparts.do?model=CD33&mospid=47501&btnr=64_0555&hg=64&fg=15
It looks like the pipes #11 unscrew from the flange #22, at the firewall. Hopefully.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
YSmileWav---------yes, thats the part number #11 that im talking about ,you think they unscrew from inside engine compartment ,I'll give it a try -thanks .........................
I've never removed one or even looked at how I would remove it. Like I said, "hopefully" it can be removed at the firewall.
Success---the plastic triple heater tube was replaced by removing the defroster grill and lower access plate, at the firewall .The triple plastic heater tube assembly has one 10 mm nut holding it in place. Once I was able to get at it ,replacing the part was easy. The part never should be made from plastic ,
I thought BMW's were better made. Thanks for your help ,ALAN
When you say defroster grill do you mean outside the cabin below the window where the wipers are or inside the cabin?
