328is backfire
i have a 1997 328is the engine backfires wont idle and the cats get red hot can anyone tell me the problem?
Old 09-24-2008, 11:55 AM
Jeron's Avatar
Plugged cats?
Way too rich?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-24-2008, 01:20 PM
cats are not plugged looks like its dumping fuel cats breifly cought fire!!!
Old 09-24-2008, 01:50 PM
could this be a computer problem??
Old 09-25-2008, 09:04 AM
Jeron's Avatar
Seems unlikely. Do you have a check engine light?
I'm just guessing but I'd start with injectors.
Old 09-25-2008, 11:11 AM
If this car had a timing belt driving the cams rather than a chain, I would suspect that the belt had slipped and the cams were out of time. Has the head been off?
Having the VANOs fail and fully advance the cams would screw up you idle, but should not be as bad as you describe.
Are both cats getting hot? If so, the problem is affecting all cylinders (or at least one in front and one in back).
I would start with a compression check. If compression is bad across the board, I'd pull off the cover and look at the cam timing. If compression is bad on only some of the cylinders, you will likely be pulling apart a lot more than covers.
Old 09-25-2008, 09:33 PM
No check engine light, but i have been told that the o2 sensors could be at fault does that sound right?
Old 09-26-2008, 08:38 AM
Yes both cats get REAL hot, will check compression this weekend. to my knowledge the head has not been off. Thanks.
Old 09-26-2008, 08:42 AM
Checked compression all is fine. what about the o2 sensor, possible???
Old 10-01-2008, 07:57 AM
