98 BMW 328I Blower Motor
I have a 1998 328I with climate control.My heater blower just stopped working.The readout goes up and down when you press it and shows that the fan is running,but there is no air moving.Anything common to look for outside of the motor itself?
Old 09-13-2007, 11:58 AM
Jeron's Avatar
"final stage resistor" is THE most common but it presents in different ways.
bad capacitor on the AC unit board is second most common.
If it were me I'd replace the final stage resistor, which is due to fail anyway, then go from there.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-13-2007, 02:32 PM
I have the same problem. Where is the resistor?
Old 09-30-2008, 06:12 PM
Jeron's Avatar
On E36, the final stage resistor is in the evap box on the tranny tunnel and pulls out from the dirver side footwell.
Does your fan work at all? Only on high?
Old 10-02-2008, 09:14 AM
Fan does not work at all.
Old 10-12-2008, 10:13 AM
Jeron's Avatar
If the blower does not work at all it could be the blower itself. See if you can push start it while it is "on".
Old 10-13-2008, 07:53 AM
