Help with unusual sound only when freezing
I have a weird almost moan coming from my 1997 328ic whenever outside temperatures dip. When going slow, it sounds like a clicking and as I go faster, it turns into a moan.
It is definitely speed related and seems to have nothing to do with the engine. I can feel it in the gear shift (I have an automatic), and it does not go away when I put the car in neutral (while rolling). Braking doesn't seem to affect it (aside from the speed of clicking changing), so I guess it's not the brakes.
It goes away after 5 - 10 minutes of driving (warmed up I'm assuming?). I only notice it while cold and the ambient temperature is cold. I never notice when it's 50 degrees out.
I'm just looking for any ideas as to things to look at.
Old 03-09-2009, 09:16 AM
Jeron's Avatar
The only things that it could be based on your description, is the Tranny, center support bearing, the differential or a wheel bearing.
You may be able to isolate the Tranny and center support by running it, in the cold, with the car off the ground.
I doubt it is the wheel bearing based on your description.
My guess is it is the tranny. I would replace the tranny fliud with the proper type, probably ATF, as my first step.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-14-2009, 10:30 PM
