ozzy328i's Avatar
BMW Roundel Vibration
I have a 1997 328i, when you take a curve that has you turning the steering wheel to the right it has a bad vibration. It feels like it is on the drivers side of the car, I replaced the wheel hub assembly and that wasn't the problem. Anyone have a suggestion as to what I should try?
Old 10-07-2009, 06:30 PM
Jeron's Avatar
You replaced the wheel bearing on the drivers side?
Next is look for a loose suspension component such as tie rod end or control arm ball joint.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-07-2009, 06:42 PM
ozzy328i's Avatar
BMW Roundel
Yes I replaced the drivers side wheel hub, I wasn't sure if that was my problem but it seemed like a good place to start. I will check the tie rod end and the control arm ball joint this weekend. Thank you for your reply.
Old 10-08-2009, 07:24 PM
