Rrrockhound's Avatar
running too cool
I changed my timing belt and some other things using the timing belt/water pump super kit from Pelican. The kit came with a 71 degree thermostat for some reason (the t-stat on the car was 80 degrees). With the car back together, the temp. needle barely climbs up to the start of the blue zone. I've never seen it stay that cool. I've bled the system so I don't think the problem is an air bubble next to the temp. sensor. I'm going back to the original t-stat, but are there any other ideas?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 06-14-2010, 05:42 PM
get an ohm meter and test the resistance across the sensors. If you need the correct values I can provide them.
By the way, which car?
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 06-17-2010, 05:16 PM
Sorry, never mind, the 87, since it is the only one with a timing belt, and you are in this forum.
Old 06-17-2010, 05:22 PM
