96 318ti no spark
I've got my 96 318ti that is producing no spark. I'm also pretty sure that I'm not hearing the fuel pump. I've tested the relays fuel and DME getting 12Volts.
I want to test the Crank and cam sensors However I can't seem to find the wiring digram for the DME pins. I've looked on line with no luck.Does anyone have the a digram or know of where to find it Thank you ED |
here is the service manual:
Free PDF: BMW 3 Series 1992-1998 Service Manual - Free ebook manual download - PDFee.com I hope this works for you. Did you check the ignition coil? |
