Window trouble, window gets stuck going up...
When i try to roll up my driver's side window, the front of the window lags a bit and gets stuck, and the window rolls back down. If i force it towards the back of the car, it will roll up, however. Is it time for a new window regulator, or some other sort of a problem? Please help, this is really annoying.
1992 325i, sedan |
It sounds like the track or the gears are loose or bent or something. Have you tried looking inside the door panel?
On an e36, the plastic slider that moves down the track in the window regulator wears out eventually and pops out of place. The previous generation 5 series had a similar mechanism and they have this problem as well. The e30 3-series had a much more robust window regulator.
Instructions and pics are here. Doug's Domain :: BMW E36 Power Window Motor and Regulator DIY |
Get driver update daily.I recommend to use driver detective which will be usefull to you or it will be a virus which make these type of trouble.Just stop download the files from the internet or recommended to use Quik Heal Antivirus.
| All times are GMT -8. The time now is 01:52 PM. |
