Window trouble, window gets stuck going up...
When i try to roll up my driver's side window, the front of the window lags a bit and gets stuck, and the window rolls back down. If i force it towards the back of the car, it will roll up, however. Is it time for a new window regulator, or some other sort of a problem? Please help, this is really annoying.
1992 325i, sedan
Old 11-09-2010, 07:38 PM
Frajo's Avatar
It sounds like the track or the gears are loose or bent or something. Have you tried looking inside the door panel?
Old 11-09-2010, 10:28 PM
On an e36, the plastic slider that moves down the track in the window regulator wears out eventually and pops out of place. The previous generation 5 series had a similar mechanism and they have this problem as well. The e30 3-series had a much more robust window regulator.
Instructions and pics are here.
Doug's Domain :: BMW E36 Power Window Motor and Regulator DIY
Old 11-10-2010, 06:28 AM
I did look inside the door panel, nothing looks bent or out of place to me. I tried to put some white lithium grease on the plastic sliders, but no dice. Also, the plastic sliders were replaced just recently, because that was what I thought caused the problem, but that didn't solve it, or make any difference for that matter.
Old 11-11-2010, 05:56 PM
Get driver update daily.I recommend to use driver detective which will be usefull to you or it will be a virus which make these type of trouble.Just stop download the files from the internet or recommended to use Quik Heal Antivirus.
ipod classic
Old 11-23-2010, 06:40 AM
